NX Journal:retrieve attribute value(s) from parent part
nxexplorer
ID
I need help on NX Journal:
how retrieve attribute value(s) from parent part(one level assy). Appreciate for Any suggest.
Thank you,
NXExplorer
What version of NX are you using ?
Are you using TeamCenter ?
Jerry J.
UGV5-NX1961
Hi Jerry,
It is NX10.0.3.native nx, no teamcenter.
Maryadi
Hi
In below journal an attribute named "CALLOUT" value will be copied from parent part to child part. Parent part is the displayed part and child part is the work part.
let me know is this approach for work for you or not we can modify the journal as per your requirement.
using System;
using NXOpen;
using NXOpenUI;
using NXOpen.Assemblies;
namespace ParentAttributes
public class NXAttributes
public static void Main()
Session theSession = Session.GetSession();
UI theUI = UI.GetUI();
ListingWindow lw = theSession.ListingWindow;
try
Part wp = theSession.Parts.Work;
Part dp = theSession.Parts.Display;
Component pt = dp.ComponentAssembly.RootComponent; // Check the assembly is valid or not
if (pt != null)
BasePart parent = pt.OwningPart;
String at_val = parent.GetStringUserAttribute("CALLOUT", -1);
wp.SetUserAttribute("CALLOUT", -1, at_val, Update.Option.Now);
lw.Open();
lw.WriteFullline(pt.OwningPart.Leaf + " Attribute value: "+at_val+ " is copied to " + wp.Leaf);
else
theUI.NXMessageBox.Show("NXAttribute Tool", NXMessageBox.DialogType.Information, "This is not a valid Assembly");
catch (Exception ex)
theUI.NXMessageBox.Show("NXAttributes", NXMessageBox.DialogType.Error, ex.ToString());
public static int GetUnloadOption(string dummy) { return (int)Session.LibraryUnloadOption.Immediately; }
Hi Ram K,
Thank you for your suggestion, I will try your codes.
Actually, my requirement is in assembly when the child part as work part, asking the mother part whether it has a specific attribute or not.
Thank you,
Maryadi
Hi Maryadi,
Current code will copy the attribute value from mother part to child(work part). We can tweak this code to get your desired result, by adding "if" condition to check the attribute existence.
if (pt != null)
if( parent.GetUserAttributeAsString(){} //To get Attribute names
Ram K
ramkan8@gmail.com
Hi Ram K
I will make some changes to it to adjust for my requirements.
Thank you for your journal.
Maryadi
Hi Ram K
Here I have edited your C# Journal above, become vb.net. Maybe someone needs it in vb.
Once again, Thank you.
Maryadi
'By: Maryadi - Edited from C# Journal by. Ram K *
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.Assemblies
Module NXJournal
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim lw As ListingWindow = theSession.ListingWindow
Sub Main()
try
Dim wp As Part = theSession.Parts.Work
Dim dp As Part = theSession.Parts.Display
Dim pt As Component = dp.ComponentAssembly.RootComponent
Dim null As System.DBNull
Dim theUI As UI = UI.GetUI()
if Not String.IsNullOrEmpty(pt.ToString)
Dim parent As BasePart = pt.OwningPart
Dim at_val As String = parent.GetStringUserAttribute("Project Number", -1)
wp.SetUserAttribute("Project Number", -1, at_val, Update.Option.Now)
lw.Open()
else
End If
Catch ex As Exception
End Try
End Sub
End Module
