Nx Journaling - copy a component from single csys to multiple csys
Kumaresh_07
Automotive
IN
Hi all,
Is there any way to copy a component from single csys to multiple csys?
please refer below mentioned journal code.If you guys run below journal ,you can move component from one csys to another csys.
I want to modify below journal as like below steps.
While run the journal,
Step 1)user going to select csys of component(From csys).
Step 2)user going to select destination csys's (Here user can select mutiple Csys's)
Result : the component placed in all csys's ,which i selected in step 2.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession()
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "reposition component"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        Dim fromCsys As CoordinateSystem
        Dim toCsys As CoordinateSystem
        If SelectCsys("Select 'From' coordinate system", fromCsys) = Selection.Response.Cancel Then
            Return
        End If
        If SelectCsys("Select 'To' coordinate system", toCsys) = Selection.Response.Cancel Then
            Return
        End If
        'calculate Csys to Csys transformation matrix
        Dim fromOrigin() As Double = {fromCsys.Origin.X, fromCsys.Origin.Y, fromCsys.Origin.Z}
        Dim fromXAxis() As Double = {fromCsys.Orientation.Element.Xx, fromCsys.Orientation.Element.Xy, fromCsys.Orientation.Element.Xz}
        Dim fromYAxis() As Double = {fromCsys.Orientation.Element.Yx, fromCsys.Orientation.Element.Yy, fromCsys.Orientation.Element.Yz}
        Dim toOrigin() As Double = {toCsys.Origin.X, toCsys.Origin.Y, toCsys.Origin.Z}
        Dim toXAxis() As Double = {toCsys.Orientation.Element.Xx, toCsys.Orientation.Element.Xy, toCsys.Orientation.Element.Xz}
        Dim toYAxis() As Double = {toCsys.Orientation.Element.Yx, toCsys.Orientation.Element.Yy, toCsys.Orientation.Element.Yz}
        Dim mtx4Transform(15) As Double
        theUfSession.Mtx4.CsysToCsys(fromOrigin, fromXAxis, fromYAxis, toOrigin, toXAxis, toYAxis, mtx4Transform)
        'extract the rotation matrix and the tranlsation vector
        Dim rotMatrix(8) As Double
        theUfSession.Mtx4.AskRotation(mtx4Transform, rotMatrix)
        Dim transVec(2) As Double
        theUfSession.Mtx4.AskTranslation(mtx4Transform, transVec)
        'convert array of doubles to vector 3d
        Dim translateVector As Vector3d = New Vector3d(transVec(0), transVec(1), transVec(2))
        'convert array of doubles to Matrix3x3
        Dim rotationMatrix As Matrix3x3 = convertToMatrix3x3(rotMatrix)
        'determine component to move based on the chosen "from" csys
        Dim comp As Assemblies.Component = fromCsys.OwningComponent
        Dim componentPositioner1 As Positioning.ComponentPositioner = theSession.Parts.Work.ComponentAssembly.Positioner
        Dim network1 As Positioning.Network
        network1 = componentPositioner1.EstablishNetwork()
        Dim componentNetwork1 As Positioning.ComponentNetwork = CType(network1, Positioning.ComponentNetwork)
        Dim markId2 As Session.UndoMarkId = Nothing
        If comp IsNot Nothing Then
            markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Move Component")
            Dim movableObjects() As NXObject = {comp}
            componentNetwork1.SetMovingGroup(movableObjects)
            componentNetwork1.BeginDrag()
            'reposition component from the rotation matrix and translation vector
            componentNetwork1.DragByTransform(translateVector, rotationMatrix)
            componentNetwork1.EndDrag()
            componentNetwork1.ResetDisplay()
            componentNetwork1.ApplyToModel()
            componentNetwork1.Solve()
        End If
        theSession.UpdateManager.AddToDeleteList(componentNetwork1)
        theSession.UpdateManager.DoUpdate(markId2)
        lw.Close()
    End Sub
    Function SelectCsys(ByVal prompt As String, ByRef selObj As TaggedObject) As Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select a Coordinate system"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.AnyInAssembly
        Dim selectionMask_array(0) As Selection.MaskTriple
        With selectionMask_array(0)
            .Type = UFConstants.UF_coordinate_system_type
            .Subtype = UFConstants.UF_all_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selobj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Function convertToMatrix3x3(ByVal mtx As Double()) As Matrix3x3
        Dim mx As Matrix3x3
        With mx
            .Xx = mtx(0)
            .Xy = mtx(1)
            .Xz = mtx(2)
            .Yx = mtx(3)
            .Yy = mtx(4)
            .Yz = mtx(5)
            .Zx = mtx(6)
            .Zy = mtx(7)
            .Zz = mtx(8)
        End With
        Return mx
    End Function
End Module
Thanks in Advance,
Kumaresh.
