NX Journaling: problem using declared strings in functions.
paulakin
I am new to VBA and SNAP, and I'm having trouble getting my code to work at one particular point in the program I'm trying to cobble together.
I'm trying to make a program that will write a material from a custom library to every body of every part in an assembly. I've found a journal that I've altered to do this and I would like to add a dialog box to it to make it easier for other people to use.
The code I'm using I got from here from the poster named "jpetach."
So far I've changed the code to use a custom library and I've used the block UI styler to make a dialog box for it. I'm using a string block at the moment as I haven't figured out a way to read the entire material library into a list or a dropdown. However, whenever I declare a string that I believe is exactly the same as the strings that are manually put in the code for the material, the code throws an error in the information window: "Error running application: No object found with this name."
Essentially what I've done is this, I've taken the two lines responsible for writing the material to the part and replaced them with a variable (and changed the library).
So orginally it was this, where you would have to manually changed the "Alumnium_6061," in the code to the material you need to apply.
Code:
Try
                 'load from library in case it is not used in the part yet
                  physicalMaterial1 = workPart.MaterialManager.PhysicalMaterials.LoadFromNxmatmllibrary("Aluminum_6061")
             Catch ex as Exception
                 ' the material is already known in the part so use it
                 physicalMaterial1 = CType(workPart.MaterialManager.PhysicalMaterials.FindObject("PhysicalMaterial[Aluminum_6061]"), PhysicalMaterial)
             End Try
...and I've changed it to this, where "Mat" and "Mat2" should take the place of those two strings.
Code:
Try
                    physicalMaterial1 = workPart.MaterialManager.PhysicalMaterials.LoadFromMatmlLibrary("C:\Users\P\Documents\290\TEST\Material Library BBG&NX.xml", Mat)
                Catch ex As Exception
                    physicalMaterial1 = CType(workPart.MaterialManager.PhysicalMaterials.FindObject(Mat2), PhysicalMaterial)
                End Try
Where I've defined my variables like so:
Code:
Module NXJOURNAL
    ' Declare module variables.  These are available to all subroutines.
			 Dim theSession As Session = Session.GetSession()
    Dim alreadyProcessed As Hashtable
    Dim knt As Integer = 0
    Dim partLoadStat As PartLoadStatus
    Dim LW As ListingWindow = theSession.ListingWindow
    Dim displayPart As Part = theSession.Parts.Display
    Dim workPart As Part
	Dim Mat As String = Nothing
	Dim Mat2 As String = Nothing
...and written to from the string box in the block UI styler like so:
     Public Function apply_cb() As Integer
            Dim errorCode As Integer = 0
            Infowindow.Writeline("Hello World!")
            Dim Mat As String = Materialval.value
            Infowindow.Writeline(Mat)
			Dim Mat2 As String = "PhysicalMaterial[" &Mat &"]"
Although if I ignore the block input completely and just define my variables outright with no input the same thing occurs, for some reason it seems like the strings have to be *in* the function. What am I missing?
My entire code for reference:
Code:
Option Strict Off
Imports System
Imports System.IO
Imports System.Collections
Imports NXOpen
Imports NXOpen.BlockStyler
Imports Snap, Snap.Create
Imports NXOpen.Assemblies
Imports NXOpen.UF
Imports NXOpenUI
Imports NXOpen.UIStyler
Module NXJOURNAL
    Public Class block5
        'class members
        Private Shared theSession As Session
        Private Shared theUI As UI
        Private theDlxFileName As String
        Private theDialog As NXOpen.BlockStyler.BlockDialog
        Private label0 As NXOpen.BlockStyler.Label ' Block type: Label
        Private group0 As NXOpen.BlockStyler.Group ' Block type: Group
        Private Materialval As NXOpen.BlockStyler.StringBlock ' Block type: String
#Region "Block Styler Dialog Designer generator code"
        Public Sub New()
            Try
                theSession = Session.GetSession()
                theUI = UI.GetUI()
                theDlxFileName = "C:\Users\P\Documents\290\TEST\block\block5.dlx"
                theDialog = theUI.CreateDialog(theDlxFileName)
                theDialog.AddApplyHandler(AddressOf apply_cb)
                theDialog.AddInitializeHandler(AddressOf initialize_cb)
                '---- Enter your exception handling code here -----
                Throw ex
            End Try
        End Sub
#End Region
        Public Shared Sub Main()
            Dim theblock5 As block5 = Nothing
            Try
                theblock5 = New block5()
                ' The following method shows the dialog immediately
                theblock5.Show()
                theUI.NXMessageBox.Show("Block Styler", NXMessageBox.DialogType.Error, ex.ToString)
            Finally
                If theblock5 IsNot Nothing Then
                    theblock5.Dispose()
                    theblock5 = Nothing
                End If
            End Try
        End Sub
        Public Shared Function GetUnloadOption(ByVal arg As String) As Integer
            'Return CType(Session.LibraryUnloadOption.Explicitly, Integer)
            Return CType(Session.LibraryUnloadOption.Immediately, Integer)
            ' Return CType(Session.LibraryUnloadOption.AtTermination, Integer)
        End Function
        Public Shared Sub UnloadLibrary(ByVal arg As String)
            Try
            End Try
        End Sub
        'This method shows the dialog on the screen
        Public Sub Show()
            Try
                theDialog.Show
            End Try
        End Sub
        'Method Name: Dispose
        Public Sub Dispose()
            If theDialog IsNot Nothing Then
                theDialog.Dispose()
                theDialog = Nothing
            End If
        End Sub
        '---------------------Block UI Styler Callback Functions--------------------------
        'Callback Name: initialize_cb
        Public Sub initialize_cb()
            Try
                label0 = CType(theDialog.TopBlock.FindBlock("label0"), NXOpen.BlockStyler.Label)
                group0 = CType(theDialog.TopBlock.FindBlock("group0"), NXOpen.BlockStyler.Group)
                Materialval = CType(theDialog.TopBlock.FindBlock("Materialval"), NXOpen.BlockStyler.StringBlock)
            End Try
        End Sub
        'Callback Name: apply_cb
            LW.Open()
            LW.WriteLine("Listing child components")
            Try
                Dim part1 As Part = theSession.Parts.Work
                LW.WriteLine("Work part: " & part1.FullPath)
                LW.WriteLine(part1.Leaf)
                LW.WriteLine(CType(TimeOfDay(), String))
                ' Initialize a hash table to store components that have been processed.
                ' This will prevent components from being processed twice
                alreadyProcessed = New Hashtable
                Dim c As ComponentAssembly = part1.ComponentAssembly
                LW.WriteLine("first walk: ")
                Walk(c.RootComponent, 0)
                ' When the program is done "walking" the assembly it will return here.
                ' Set the work part back to what it was
                LW.WriteLine("Done: ")
                theSession.Parts.SetDisplay(part1, False, False, partLoadStat)
            Catch e As Exception
                LW.WriteLine("Error running application: " & e.Message)
            End Try
        End Function
        Sub Walk(ByVal c As Component, ByVal level As Integer)
            LW.WriteLine("Walking: ")
            Dim ufs As UFSession = UFSession.GetUFSession()
            'Dim wrap As String = Chr(10)
            'Dim dwrap As String = wrap & wrap
            'Dim title As String
            'Dim value As String
            'Dim inx As Integer = 0
            Dim prototype As Part
            Dim children As Component() = c.GetChildren()
            Dim child As Component
            prototype = CType(c.Prototype, Part)
            'LW.WriteLine("Component: " & child.ToString)
            LW.WriteLine("Component: " & c.ToString)
            If Not alreadyProcessed.Contains(prototype.Leaf) Then
                ' Add this prototype to the hash table so that we don't process it again
                alreadyProcessed.Add(prototype.Leaf, prototype.Leaf)
                knt = knt + 1
                Dim msgText As String
                msgText = knt.ToString & " " & New String(" "c, (level * 4)) & prototype.Leaf
                'LW.WriteLine(msgText.ToString)
                theSession.Parts.SetDisplay(prototype, False, False, partLoadStat)
                '           displayPart = theSession.Parts.Display
                Dim workPart As Part = theSession.Parts.Work
                Dim physicalMaterial1 As PhysicalMaterial
                Try
                End Try
                Dim bodies As BodyCollection = workPart.Bodies
                Dim solidBodies(0) As NXObject
                Dim counter As Integer = 0
                Dim bodyCount As Integer = bodies.ToArray.Length
                LW.WriteLine("Total Bodies in Work Part: " & bodyCount.ToString())
                If bodyCount > 0 Then
                    For Each thisBody As Body In bodies
                        If thisBody.IsSheetBody.Equals(False) Then
                            ReDim Preserve solidBodies(counter)
                            solidBodies(counter) = thisBody
                            LW.WriteLine("Solid Body: " & thisBody.ToString())
                            counter += 1
                        End If
                    Next
                    Dim solidBodyCount As Integer = solidBodies.Length()
                    LW.WriteLine("Solid Bodies in Work Part: " &
                                    solidBodyCount.ToString())
                    ' At this point, all solid bodies
                    ' should be in an array called solidBodies
                    If (solidBodies.Length > 0) Then
                        physicalMaterial1.AssignObjects(solidBodies)
                    End If
                End If
            Else
                LW.WriteLine("Already processsed")
                'theSession.DisplayManager.MakeUpToDate()
            End If ' not already processed
            For Each child In children
                LW.Writeline("next child = " & child.ToString)
                Walk(child, level + 1)
            Next
        End Sub
    End Class
	End Module
The variables Mat and Mat2 are declared twice, which will cause all kinds of confusion.
