lklo
Industrial
- Nov 24, 2010
- 226
Hi guys...
Right now I'm configuring our Routing environment...Work in progress, but goes very well.
We are using NX 11 and Tc 10...
I have two questions for you guys,:
#1: How to use the Routing BOM template part, if this template resides in teamcenter..?
In NX customer default it seems like it is only possible to specify a path to the BOM template, in the windows OS environment...But I need to be able to specify the teamcenter database number and revison, instead....
But I cant find any "fields" in customer default, that will allow me too do this....
Maybe I have missed something....?
#2: Right now in my test environment, I'm using my customized Routing BOM template from the windows OS system...just when testing and developing the layout of the BOM template...Everything goes well....Except one thing: I have tried over and over, to set the lettering preference of the entire section, to "regular"....But when I create a Routing BOM afterwards, on some existing drawingsheets - the BOM is always formatted as "bold"....I really dont under stand this behavior.....Specially not, because if I simply make a copy the BOM template into the clipboard, and the afterwards paste it onto an active drawingsheet, the lettering preference of the entire section, is "regular"....as expected....!!
Maybe one of you guys, have a solution...or maybe is also strugling with the same issue...
regards lklo
regards lklo
