Friday at 7:11 AM #1 A Argmnt Computer Nov 27, 2024 4 Background saving drawing files in NX10 makes problem with CGM in Viewer TC. Its makes cgm with empty sheets. Can someone help with this problem?
Friday at 12:52 PM #2 Toost Mechanical Jan 18, 2011 2,970 How is this option enabled in your environment ? If you load a drawing and then go File- Save- Save options Is the "save drawing CGM data" = on ? I assume this is the option we are talking about. Regards, Tomas Upvote 0 Downvote
Friday at 1:02 PM Thread starter #3 A Argmnt Computer Nov 27, 2024 4 yes, this option is enabled. For example: 5 edited prt with draw sheet open in NX10. Next closing NX and press ok for save all. Result: cgm will be not empty on 1 UGMaster in TC (active window on save), in another 4 (background window on save) its will be empty. Upvote 0 Downvote
