Objective = Need to go into preference object and change the line type to dash, line thickness to .7, then open the Rectangle function. (Not the sketch rectangle)
I recorded a journal and it does the job of changing the line attributes, but it doesnt open the rectangle function. If it does open it, it is closing it again before the journal ends. But I need the rectangle function to open and be left open so the operator can select the two points for creating the rectangle.
The ultimate would be for the journal to change the preferences for the line attributes, open the rectangle function, then wait for the operator to select the two points to create the rectangle and after the second point is selected, it would automatically go back and change the preferences back to solid line and .18 thick.
This seemed like a much more difficult task so I figured just ending the journal after opening the rectangle function would do. I already have a button they can hit that would return the attributes back to the standard settings.
