NX1872 - Journal fix please
Kenja824
Automotive
Nov 5, 2014
949
I had a journal to import a part file. I was able to adjust it to bring in a part from Team Center easily enough. I stole some functions from another journal I had to make it so the user selects where the part file is placed in drafting. There are two things I cant figure out.
1) How to make it so you have to select an existing point inside a drafting view to place the part file. (Currently it is set to cursor point)
2) To make it loop so the user can keep selecting existing points and keep importing the same part file repeatedly.
If anyone can help with this, it would be appreciated.
Current Journal Code...
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Sub Main(ByVal args() As String)
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        '   Menu: File->Import->Part...
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "Import Part")
        workPart.Layers.WorkLayer = 253
        Dim partImporter1 As PartImporter
        partImporter1 = workPart.ImportManager.CreatePartImporter()
        ' partImporter1.FileName = "R:\hms_tools\NX1872\Tooling\part\Notes\break_corners.prt"
        partImporter1.FileName = "@DB/ANK37226/001"
        partImporter1.Scale = 1.0
        partImporter1.CreateNamedGroup = False
        partImporter1.ImportViews = False
        partImporter1.ImportCamObjects = False
        partImporter1.LayerOption = PartImporter.LayerOptionType.Work
        partImporter1.DestinationCoordinateSystemSpecification = PartImporter.DestinationCoordinateSystemSpecificationType.Work
        Dim element1 As Matrix3x3
        element1.Xx = 1.0
        element1.Xy = 0.0
        element1.Xz = 0.0
        element1.Yx = 0.0
        element1.Yy = 1.0
        element1.Yz = 0.0
        element1.Zx = 0.0
        element1.Zy = 0.0
        element1.Zz = 1.0
        Dim nXMatrix1 As NXMatrix
        nXMatrix1 = workPart.NXMatrices.Create(element1)
        partImporter1.DestinationCoordinateSystem = nXMatrix1
        Dim destinationPoint1 As Point3d = SelectScreenPoint() '= New Point3d(0.0, 0.0, 0.0)
        partImporter1.DestinationPoint = destinationPoint1
        Dim markId2 As Session.UndoMarkId
        markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Import Part Commit")
        Dim nXObject1 As NXObject
        nXObject1 = partImporter1.Commit()
        theSession.DeleteUndoMark(markId2, Nothing)
        partImporter1.Destroy()
        '   Menu: Tools->Journal->Stop Recording
    End Sub
    Function SelectScreenPoint() As Point3d
        'Allow user to interactively pick the point where the annotation
        'will be placed.
        'This Function needs Sub MotionCallback() to work properly.
        Dim myScreenPos(2) As Double
        Dim theViewTag As Tag = theSession.Parts.Display.Views.WorkView.Tag
        Dim theResponse As Integer
        theUfSession.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        theUfSession.Ui.SpecifyScreenPosition("pick a point", AddressOf MotionCallback, Nothing, myScreenPos, theViewTag, theResponse)
        theUfSession.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
        If theResponse = UFConstants.UF_UI_PICK_RESPONSE Then
            Return New Point3d(myScreenPos(0), myScreenPos(1), myScreenPos(2))
        Else
            Return Nothing
        End If
    End Function
    Sub MotionCallback(ByVal pos() As Double,
               ByRef motion_cb_data As UFUi.MotionCbData,
               ByVal client_data As System.IntPtr)
        'This sub will be called every time a cursor move is detected during the
        'SpecifyScreenPosition function.
        'The parameters motion_cb_data and client_data are not used in this implementation,
        'but the Sub must have the same signature as UFUI.MotionFnT to work properly.
        'disable (for now)
        'Return
        Dim wView As NXOpen.View = theSession.Parts.Display.Views.WorkView
        Dim topLeft(2) As Double
        Dim topRight(2) As Double
        Dim botLeft(2) As Double
        Dim botRight(2) As Double
     End Sub
    Function mask_for_curves(ByVal select_ As IntPtr, ByVal userdata As IntPtr) As Integer
        Dim num_triples As Integer = 4
        Dim mask_triples(3) As UFUi.Mask
        mask_triples(0).object_type = UFConstants.UF_line_type
        mask_triples(0).object_subtype = 0
        mask_triples(0).solid_type = 0
        mask_triples(1).object_type = UFConstants.UF_circle_type
        mask_triples(1).object_subtype = 0
        mask_triples(1).solid_type = 0
        mask_triples(2).object_type = UFConstants.UF_conic_type
        mask_triples(2).object_subtype = 0
        mask_triples(2).solid_type = 0
        mask_triples(3).object_type = UFConstants.UF_spline_type
        mask_triples(3).object_subtype = 0
        mask_triples(3).solid_type = 0
        theUfSession.Ui.SetSelMask(select_,
                UFUi.SelMaskAction.SelMaskClearAndEnableSpecific,
                                          num_triples, mask_triples)
        Return UFConstants.UF_UI_SEL_SUCCESS
    End Function
End Module
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
