NX19 series - fatal hanging QtWebEngineProcess.exe
cjfx
Computer
Our software company is facing issues with QtWebEngineProcess.exe hanging and not terminating when run through the Jboss/Wildfly server that hosts our software to a webpage. When we run the same commands from a command prompt it works fine without hanging. We do not face this problem with NX10, NX11, or NX12. I haven't tested if the hang is also present with the NX18 series or NX20 series yet but we need this to work in NX1953.
Does anyone have any ideas as to what could be causing this hang, or how we could tweak the arguments passed to this exe to see which could be causing the issue? I can't simply delete the .exe file because it causes a fatal error when loading NX1953, even though the exe doesn't exist in NX10, NX11, or NX12.
