I'm writing a small program to allow a user to add specified text to selected dimensions. Depending on the orientation of the selected dimensions, the placement of the text will vary ("after" for horizontal dimensions, "below" for vertical). Some dimensions are a subtype that is neither 1(horizontal) nor 2(vertical), and therefore require further user input to decide where to place the appended text (after or below).
What I want to do is have the user select all the dimensions to which they want to append text. Then, if any of those are not subtype 1 or 2, cycle through the dimensions in question, highlighting each in turn and asking where the appended text should go.
The problem is that the .Highlight() Method doesn't appear to be working as I had hoped. The .Highlight() Method doesn't seem to be updating the dimensions' highlighted status mid-journal, as I would need it to in order for the user to know what dimension needs a decision to be made. From what I can tell, highlighting only works how I'd like it to while the user has just selected an object with the SelectionManager. You can see what I'm talking about if you run the code below. After selecting a dimension, it is added to a list which is then cycled through and each item highlighted in turn. As long as you keep selecting new dimensions, this works as intended. Once you respond with anything other than selecting an object (Back, Cancel, or Ok), the highlighting loop stops working.
If this is just a how NXOpen works, I can find a way to live with it. But I'm hoping there's a way to make highlighting work the way I'd prefer, rather than working around it.
Code:
' LOUIS HOLM
' 03-07-22
' RED BUD INDUSTRIES
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
Dim objUI As UI = UI.GetUI
Dim objUFS As UFSession = UFSession.GetUFSession()
Dim objSession As Session = Session.GetSession()
Sub Main (ByVal args() As String)
Dim intResponse As Integer
Dim objSelected As TaggedObject
Dim pntSelect As Point3D
Dim lstSelected As New Collections.Generic.List(Of TaggedObject)
Dim intType As Integer
Dim intSubtype As Integer
Dim objDisplayable As DisplayableObject
While intResponse <> 2
intResponse = objUI.SelectionManager.SelectTaggedObject("prompt", "title", Selection.SelectionScope.AnyInAssembly, False, Selection.SelectionType.All, objSelected, pntSelect)
If Not lstSelected.Contains(objSelected) And objSelected IsNot Nothing Then
lstSelected.Add(objSelected)
End If
For Each fSelected As TaggedObject In lstSelected
objUFS.Obj.AskTypeAndSubtype(fSelected.Tag, intType, intSubtype)
If intType = 26 Then ' Is Dimension
objDisplayable = CType(fSelected, DisplayableObject)
objDisplayable.Highlight()
MsgBox("Highlighted selection has subtype: " & intSubtype)
objDisplayable.Unhighlight()
End If
Next
End While
End Sub
End Module
