On one of our drawings, it seems that all the dual dimensions are off. By 'off' I mean that the inches would be correct, but the mm would not. For the ones that were set up as 'limit', we were able to correct the issue by changing the +/- values on the mm. However with the 'basic' dimensions, we are unsure why the mm would not convert correctly from inches. Again we're in NX6, so the options to resolve this for newer versions do not seem to be available.
Thanks!
Thanks!
