DeKa
- Sep 18, 2003
- 5
Hello to all!
I am trying to insert the array of screws in the circular array of holes, which was made in the detail. That detail was inserted to an assembly and was promoted. But on the step when Itry to create an array of screws, the error message is always appeared "Array template is not mated to a valid feature instance".
Here the every step I do.
I create new detail, create cylinder feature there.
create simple hole on the plane face, create circular array of the holes.
I create an assembly, insert the detail to that assembly, fix the detail by creating fix constarint [I do not use mating conditions].
Then I promote my detail.
After that I insert my screw to the assembly, create 2 touch constraints to place my screw in the hole: the first one between screw cylindrical face and promoted hole cylindrical face, the second - between screw plane face and promoted detail plane face.
Then I try to create an array of screws(from instance feature) in the assembly.
The result is the error message.
What can be wrong?
If I do not create promotion everything is fine.
What can be wrong?
