so a few months ago we went from NX6 to NX9. the issue I have is in the non cutting moves menu, engage and retract tab, NX9 seems to change or maybe default the minimum clearance value to 50.0 percent of tool, this seems to override any value we have in the length area. this has actually caused me to crash a machine because the engage changed from the linear length value engage of .2 inch to a 50% minimum of tool which made the engage .9 inch. So question is, is the minimum clearance value a customer default value that can be changed or is there something else that we can do to prevent our engage and/or retract values from changing to the 50% Tool value when paths are regenerated.
