NXjournal: Eval.AskArc problem 2406
MANox
127
many time ago I wrote journal and I used in then some function:
Code:
Dim theUfSession As UFSession = UFSession.GetUFSession()
Code:
    Function GetArcCenter(edge1 As Edge) As Double()
        Dim centerCoords As Double()
        Try
            Dim edgeTag As NXOpen.Tag = edge1.Tag
            Dim estruct As System.IntPtr
            theUfSession.Eval.Initialize2(edgeTag, estruct)
            Dim evalArc As NXOpen.UF.UFEval.Arc
            theUfSession.Eval.AskArc(estruct, evalArc)
            centerCoords = evalArc.center
            Dim diameter As Double = evalArc.radius
        Catch e As Exception
            centerCoords = Nothing
        End Try
        Return centerCoords
    End Function
And in NX2007 it works.
But now I update to NX2406 and when I delete Try Loop I have error 8 line:
NXOpen.NXException: The first parameter passed in was invalid.
w NXOpen.UF.UFEval.AskArc(IntPtr evaluator, Arc& arc)
Do You have any suggestion why this don't work?
Best regards
MANok
NX2406
Tc2412
