Currently I am running a steady state simulation, on ASPEN PLUS (I have only a few years of experience in the usage of ASPEN PLUS), for a Pharmaceutical plant. It's a batch process and I am using a BATCHSEP model in this simulation. The feed comprises Na2co3 along with Dichloromethane, Butyrophenone, 3 Methylpropiophenone and 4 Methylpropiophenone.
The simulation converged but with a warning that Na2Co3 could not be identified properly and hence some of it's properties were not evaluated accurately and some properties were missing (the control panel had messages indicating that the thermodynamic package used viz. initially NRTL and later changed to UNIFAC by the user, was not being accepted by Na2CO3 and hence the properties may not be accurate). The result was that the desired purity of the product i.e. 4 Methylpropiophenone could not be obtained in the distillate stream (product stream).
I wish to know:
a) Since NRTL and UNIFAC do not seem to be able to estimate properties for a product mix of an inorganic compound viz. Na2CO3 and the other organic compounds what would be the appropriate thermodynamic package to be used?
b) There are specific operating steps running in a certain sequence and time duration in this Pharma production process. How would it be possible to get stream results at the end of each operating strep that is being simulated in sequence on ASPEN PLUS?
If needed I can attach a copy of the simulation file for anyone to take a look.
Thanking you in anticipation
I wish to know:
