off spec piping
mariolucas75
96
Dear forum,
There is a vessel constructed to an ASMVE VII div 1 code (At least as datasheet says).
Vessel nozzle spec says: 4", wall thickness 1.305"
But, in schedule table there is no 4" pipe having thickness 1.305".
Maximum thickness for 4" pipe is 0.674" = 17.12mm (XXS).
Having done physical measurements: ID ~97mm / 3.81"
OD ~ 163,24mm / 6.42""
If the vessel is constructed to an ASME should not it have an ASME compliant piping ? Is it kind of some off spec piping (some custom piping) ?
Looks like someone did a typo on the 4inch and meant 6 inch?
But that is gun barrel stuff. What sort of pressure is this?
If it has a signed off form (A1?) then see what it says.
But yes you can have custom piping.
Design pressure is 14 bar....
Even if it is a typo 6 " also would not have that thickness...
Suppose it is a "gun barrel" or "heavy bore" piping - is there some kind of standard for such thick "things" ?
Even heavy barrel doesn't match the OPs physical measurements, which would work if this was a 4" nozzle, but looks like a 6 inch nozzle, with 4" HB ID.
At thise sizes, the physical strength aspect would have more of an impact.
Dear forum,
Why do you say the nozzle has to be from a pipe? As long as it meets the acceptable material by the Code, it can be fabricated by other methods too.
