Hi all!
I am quite a fresh engineer working on a project where cvt:s are added to 110 kV system for metering and residual voltage protection. Used VT's have two secondary windings: star, and broken delta secondary winding for Uo detection and apparently this winding should also be used for ferroresonance dampening via a resistor. the winding is rated 100/3 V for 50VA, so the resistor should be a 120 ohm resistor, right? Should the resistor be installed parallel or in series with the protection relay, and why?
thanks in advance
thanks in advance
