one shot 1
curious125
39
Does anyone have, or know where one could aquire a schematic for a pneumatic oneshot?
I'm curious what you mean by oneshot. I did a google search and found the oneshot glue system and a oneshot part insertion gun. I don't have the schematic but wondered what you were talking about.
it would basically be a momantary pulse(usually adjustable)from a steady state source. It is used a lot in electronics, where you want an output to "pulse" on and off again after a certain amount of time has gone by.
I can make an electronic version, but I was hoping to kee the application a little simpler by doing this with pneumatics instead.
Don't know exactly what you're trying to do, but almost all urinal flush valves are basically one shots.
TTFN
call your local pneumatics supply shop. they'll order you the right valves for your application. looks like you just need a on delay valve and whatever control valve you need to "fire" the delay
thanks dvd, that is exactly what I was looking for.
