Open Files as Read Only
jzecha
Aerospace
I have a VBA Macro that opens files and then saves them to a different directory.
Is there a way I can open the files as Read Only so that when Catia activates associated links, it doesn't save the file in the initially loaded location before moving it to the new location?
How do I do that in with VBA code?
Hi jzecha.
Try this.
Code:
'vba read only open sample
Option Explicit
Private Const READONLY = 1&
Sub CATMain()
    Dim path As String
    path = "C:\temp\Part1.CATPart"
    If Not isExist(path) Then
        Dim msg As String
        msg = "File not found" & vbCrLf & path
        MsgBox msg
        Exit Sub
    End If
    Dim backupAttr As Long
    backupAttr = getAttributes(path)
    If Not (backupAttr And READONLY = READONLY) Then
        Call setAttributes(path, READONLY)
    End If
    Call CATIA.Documents.Open(path)
        Call setAttributes(path, backupAttr)
    End If
End Sub
Private Sub setAttributes( _
    ByVal path As String, _
    ByVal Value As Long)
    Dim fso As Object
    Set fso = CreateObject("Scripting.FileSystemObject")
    fso.GetFile(path).Attributes = Value
End Sub
Private Function getAttributes( _
    ByVal path As String) _
    As Long
    Dim fso As Object
    getAttributes = fso.GetFile(path).Attributes
End Function
Private Function isExist( _
    As Boolean
    Dim fso As Object
    isExist = fso.FileExists(path)
End Function
