Working on a project that has four stories and part of the flooring area is steel grating and the balance of the area is concrete slab. The grated floor area contains vertical vessels that go pretty much the full height of the building. The client wants the grating around these vessels.
The floors are not horizontal assemblies and fire protection isn't required. When I read the code, I understand it that you can't have four story unprotected openings. And I am assuming that the grating is an opening, because it doesn't prevent travel of fire between levels.
Has anyone run into this before? Would the grating not be considered any opening?
