Output for Load Case in Prokon Software
qwerty122
6
Can anyone know how to make the safety factor uplift (ULS) appear in the load case for design in prokon?I've tried to input the same data but when it comes to the design part I'm getting safety factor slip (SLS).I don't know if I need to setup any parameters for it to be changed.And I'm using the code BS8110 - 1997.Kindly check the attached file for reference of the correct output.
 https://files.engineering.com/getfile.aspx?folder=103b985d-d909-4040-991b-338427b8706d&file=Sample.pdf
