output SSD complex magnitude values 1
Frankie183
22
Good morning,
I've established a SSD analysis and obtained the FRF.
What I'm looking for is a way to capture the complex magnitude (which I find in Result options - complex form - magnitude) and export the data to a txt file. It would be perfect if I obtain three columns with values for:
Frequency Modulus phase
etc.
Then I would like to automate this, to say, for instance in the .inp file that I need to output the complex magnitude and phase values. However, I can't find the correct way to call for these outputs in 'XY data from ODB field output' yet - if even available.
I also tried to capture the whole series of establishing the FRF by the macro manager, but also here, I am stuck with the fact that I can't save the output magnitudes to a txt file.
Do you guys have any recommendations? I'm stuck with it for a while already unfortunately.
Greetings and thanks in advance,
Frank
You can use Report —> Field Output or Report —> XY to export results to text file (.rpt format).
