Hello, We are working on an over-molding part in which Brass over mold with Nylon 6 30% GF. A design like the cylindrical brass part with knurling or some grooves from over-molding face and plastic covered with open one end like cap design. After over-molding we find some samples having air leakage from the joint between plastic after testing 120 psi pressure. Also, some samples are tested with a maximum 80° C temperature and after testing with 120 psi pressure find air leakage from the joint between the plastic. How will avoid air leakage? We take lots of trials please advise a solution.
