We are not a utility, but we manage a large network of distribution and transmission lines that feed critical loads. Recently, we experienced some lightning-related outages on our 34.5kV circuits. Upon investigation, we found that the footing resistance of the structures was quite high, leading to backflashovers.
I’m curious about the merits of conducting footing resistance measurements regularly to ensure that the resistance values remain within the required standards. For those with a utility background, what is the typical practice? Are footing resistances measured on a periodic basis for all circuits, regardless of the voltage level, or is this done on an as-needed basis?
