bugbus
- Aug 14, 2018
- 533
I have a situation where some lightweight decorative steel panels need to be connected to an existing wall.
For visual reasons it is important for all the panels to line up precisely, including along the length of the wall (to ensure equal gaps between panels) and in the direction towards/away from the wall (to ensure all panels are at the same distance from the wall and flush with each other). In the vertical direction, any required tolerance would be achieved by shims/packers.
Is it permissible to have a slotted hole in both the wall connection and also the panel connection, so that when viewed from above the slotted holes overlap to form a '+' arrangement allowing adjustment in any direction?
The forces on the connections are very small, and do not include the weight of the panels themselves.
