CuMo
- May 1, 2007
- 147
I've been trying to find further information but so far not successful.
As far as my knowledge goes: it is permitted to fillet weld a nozzle reinforcing pad on top of a main circumferential or longitudinal butt weld seam (Type A or B)
provided the main seam is first 100% X-Ray examined and the intersecting welds are as perpendicular as possible, also maintaining 2t (or 50mm) weld toe to toe distance (whichever is greater).
I am designing a Ti Gr.2 (SB-265) vessel in lethal service to ASME VIII-1 2019 but the client wants some nozzles to be re-positioned so that inevitably
some nozzle pads will have to sit on top of circumferential weld seams.
Are you aware of anything in ASME VIII-1 2019 that will forbid such practice?
I'd like to avoid overlapping weld seams if possible but if the code doesn't explicitly forbids it - then we have no reason to say 'No'.
Any help appreciated.
Many thanks!
P.S. The vessel is not U-stamped.
Many thanks!
