Hello there, guys, thanks a lot for your attention.
I use NX 2212, and I was searching high and low to override the default shortcuts for "Make ..." commands (e.g. Make Coincident (X), Make Collinear (C) etc.) in Sketch Task Environment, which are also available from Sketch scene bar, but every time I fall short because I cannot find these commands in Customize keyboard's command list. I've reviewed literally all categories. What's the trick? Is it possible at all?
Thank for your help.
NX 10.0.3.5
NX 10.0.3.5
