Materofact
- Feb 21, 2015
- 42
for metal buildings for instance, it is common to use the overstrength factor to avoid ductility requirements, etc in the ACI. overstrength is applied in order to design the bolt size and depth (also, there is a common design method to "ignore concrete breakout in tension and/or shear" by providing steel(stirrups for instance)in the footing that will take the entirety of those overstrengthed loads). QUESTION:
is it right to assume that these steel stirrups IN the footing itself ALSO need to be designed withthe overstrength factor.. seems yes, to be "safe" but there is a discussion happening in the office.
