P numbers
erichenry
Industrial
May 20, 2015
15
0
0
I have a problem can anyone explain to me if there is a such thing as Inconel 825 or is it call alloy 825. also what P-number does this material fall under and what filler metal do i use.
Question: A welding procedure specification (WPS) that is qualified with a base material SA 106 Gr B (P-No. 1 Group 1) be used with a base material ASTM A 350 Gr LF2 Class 1 (P-No. 1 Group 2)? The WPS was qualified to Section IX - 2013 using SMAW and filler metal 7018 G.
A welding procedure specification (WPS) that is qualified with a base material SA 106 Gr B (P-No. 1 Group 1) can be used with a base material ASTM A 350 Gr LF2 Class 1 (P-No. 1 Group 2)? The WPS does not have a PQR qualified with impact testing. The WPS was qualified to Section IX - 2013 using SMAW and filler metal 7018 G.
