PA6
Irwin
148
Can somebody tell me the physical properties of PA6 material? (E,nu,G, rho limit values: REH, UTS etc.)
Irwin
There are many grades, and the properties depend on a number of processing conditions and ambient conditions as well as the grade.
Can you explain what you need the properties for, and any details of the grade, conditions and application.
pat pprimmer@acay.com.au
Sorry, but I knew only the name of the material and part where it is used. This part is a cover of a switch in the car. This switch turn on and off the lights and the indicator lights.
That is it!
My problem is: I found several data on the but those are in a very wide range!
Ervin
