dfsantos
- Apr 27, 2020
- 3
We currently have an installed 6" CL300 piping which has 20mm gap between two flanges. We want to fit up avoiding rework on spools and one idea is to install a paddle spacer to fill the gap. Checking ASME B16.48 the spacer standard thickness for this size is 15.7mm, so I would like to know if it is possible to use a thicker spacer in order to bolt it up. I know that we can calculate the minimum thickness, but I could not find anything related to maximum thickness.
Thanks!
Thanks!
