HI
I want to know If I Can use the A572 Gr 50 material for made of paddles blank and spacers because this material in the standard ASME 16.48 is not refrenced and the paddles will be installed in a pipe line with temperature operation is about 190°F and pressure operation is between 1800 psi to 2000 psi. It is the material A572 Gr 50 properly specificated ?.
Thank you
Thank you
