Applet123
- May 17, 2004
- 4
I am designing a lifting padeye for a jacket. The main plate thickness comes up to about 100mm and the cheek plate is about 50mm. I specified through thickness property for both the main plate and cheek plate. My client wants to know why through thickness property is required for the plates.
The only reason I could think of is that there may be impact loads on the padeye therefore we need the padeyes to be of through thickness property to satisfy the Charpy impact test.
Is there any other reason why through thickness plates are required? It seems pretty common to use through thickness property plates for padeyes.
