As-Lag
- Aug 6, 2019
- 56
Hello
I am being asked to provide the support for two beams that sit on a 215mm block wall. The wall itself is being built using 7N blocks laid on their side. To support the beams, I intend to strengthen the blocks under the supports. My question is - am I able to use C40 440x215x100mm padstones laid flat? Also, if I am able to use padstones, what would be the normalised strength of the block for use in Eurocode calculations please?
Dan
Dan
