painting abs
mrlizzard
Automotive
Feb 28, 2008
23
I’m looking to get painted some small plastic brief case shells. They are vac formed from 3mm ABS sheets.
I was looking into pre colored sheet material but because I want the wide range of colors/effects I’m going for a painting solution.
With painting I’m worried that they will scratch, flake and discolor under UV exposure. Will they? Are there any protective coating that will help?
Any advice much appreciated?
Automotive paints don't fade much anymore. Find out what paint manufacturers and auto body shops are using.
