Parallel horizontal shims that slide frictionless on vertical rods 1
phill86518
1
Horizontal shims that slide on vertical rods:
I have 10 long aluminum horizontal shims (nearly 8'') that have two identical holes (diameter nearly 0.5") on one end. Two vertical rods pass through each of these holes such that the 10 shims are stacked. These shims are required to be perfectly parallel to each and to the ground but currently, because of the suspension from one end, the shims' far ends tend to collapse on each other creating a slant.
I need a solution that not only solves this but ensures that the shims can slide up and down the rods (almost) frictionless perfectly aligned and parallel to one another. I also cannot use any grease.
Would appreciate any help!
Can you provide a sketch of this arrangement with some dimensions? Preferably one that shows the ideal situation, and another that exaggerates the "shim's far ends" collapsing on each other effect.
Also, you're going to need to define how much deviation from perfect is acceptable.
Yeah my first thought is that this system is practically designed to lock / grip the rods.
So how are you going to address the requirement of keeping the shim stack parallel to ground?
I would consider using a tighter clearance hole, maybe located in the middle of the stack, that has a dowel pin in the middle and increase the clearance on the 1/2" holes as much as possible. Don't let the shims touch the rods.
