Parallelism(Pitch) w/respect to Specific Angle(Yaw)?
Bewler
11
I have multiple objects that are stacking together. I realized parallelism doesn't specify the positive or negative angle of parallelism so objects may be acting in the same parallel stack or against each other.
1.)Is there a way to specify the positive or negative angle of parallelism?
The more complicated question is based on a mounting surface. If I callout the parallelism the mounting piece could have angular(pitch) directed anywhere in 360 degrees of yaw. Is there a way to control a specific plane with angular orientation of parallelism for a part so for example, "45 degrees in the XY plane, part N will be parallel in the positive direction less than .XXX"?"
Sounds possibly expensive but I would spec parallelism such that my worst stackup would be acceptable or change the design. You might look at reducing or combining elements in the stackup.
