parameter a2 of Figure UW-13.2 Sketch (r) and (s)
Tridiartha
ID
I would like to seek advices regarding the physical intrepretation of variable a2, as shown in ASME VIII Div 1, Figure UW-13.2 Sketch (r) and (s).
In those sketches, variable a2 is related with a construction line (with minimum 45 degree angle).
What is the purpose of this construction line?
Where could i find in the code, a relation between parameter a2 and ts?
I appreciate for any advices related with this matter.
Thank you.
Tridiartha
Tridiartha, first you need to thoroughly understand UW-13(e) and (f) rules for corner joints with flat heads, tubehseets, etc. UW-13(f) and sketches (r) & (s) provide alternate rules to UW-13(e) and related sketches and can produce a joint with perhaps less preparation and deposited weld than UW-13(e) joints.
You need to understand that use of UW-13(f) requires some knowledge of the ratio between the tensile strength in the in-plane and through thickness (Z) directions of the flat member of the joint (the K value). The less difference between the two, the less joint prep needed.
The detailed requirements are too complicated to go into just now, but to briefly answer your questions:
1) "What is the purpose of this construction line?" - The purpose is to more or less establish the weld penetration beyond the bevel (if any) required based on the assumed or known ratio between the tensile strengths, the K value.
2) "Where could i find in the code, a relation between parameter a2 and ts?" - It is found in the detailed requirements of UW-13(f), understanding that ts is first determined under the other relevant Code rules. a2 is then determined based on the details of the weld joint and other UW-13(f) rules.
Again I say, you need to first thoroughly understand UW-13(e) and (f) rules.
Mike
Hi Mike,
Thank you for the advice.
I have made a sketch to refine my question. Please refer to the attached sketch.
Is it correct to intrepret that point A (on that sketch) was the starting point of construction line?
Tridiartha
 https://files.engineering.com/getfile.aspx?folder=6a13fae8-3990-4f15-8079-97d712a515dd&file=Figure_UW-13.2_Sketch_(s).PNG
Tridiartha, yes that looks right to me.
Do you believe that all the conditions stated in UW-13 (f) can be met during manufacturing and inspection?
Did you read SA-770?
Do you understand the K factor?
I suggest that you consult a welding engineer and a manufacturer.
I also suggest that you change the design.
