RAGE69
- Sep 21, 2016
- 2
Need to demolish a section of an existing masonry brickwork chimney - section between ceiling and ground floor needs to go while maintaining the section from ceiling level and above. Section of chimney to be retained is 470mm X 470mm and about 3.0m high.
The builder wants to just use steel beams to support the chimney.
Should there be a steel framed collar fixed to the chimney (say just below roof level) and braced back to these steel beams?
