Hi All,
I am used to calculating pressure mains which are assumed to be "flowing full" pipes.
Now, I was requested to size for a gravity line (Water Transmission) which I assume is a "partially filled" flowing pipes. Is there a standard formula to compute for the actual percentage filled of depth of water passing through the pipes? Manning Formula seems helpful but it looks like it assumes flowing full pipes or open channel system.
Thanks!!!
Thanks!!!
