Mitch Martin 120
Automotive
I have a question as to whether an intended "non-load bearing" wall actually bears some load and how (or whether) to determine how much. Here are the facts:
1. Roof=gabled and stick built
2. Two story house 29' x 38'. Beam in the basement divides the 29' span into roughly 16' and 13'.
3. First floor joists - span 16' from foundation to beam. Douglas Fir 2x10 and double every other one 16" OC.
4. Second Floor joists - 2x10 Douglas Fir double joists 16" OC that span almost 17' and run between the exterior wall and an interior load bearing wall. This interior load bearing wall almost sits on top of the beam (the wall actually sits on the 13' first floor joists "just on the other side of the beam").
A contractor installed a small wall to create a closet. The new wall runs perpendicular to the floor joists and is about 4 feet from the interior load bearing wall (and parallel to such wall) and is just over 2.5 feet long. It was built with a double top plate and 2x4 studs. There is no gap between the top plate and the joists (all of this from pics from the time). At the time it was built, the second floor joists were essentially fully loaded and the first floor joists were somewhat loaded but additional cabinets/quartz countertops have loaded the first floor joists around the margins. Four second floor joists (2 sets of double joists) run over this wall and continue on to the load bearing wall.
The question is whether this wall is taking a load for purposes of determining whether the first floor is overspanned given some additional live and deal load that is planned. If the 17' second floor joists were not continuous but cut and terminated on the closet wall (which is NOT the factset), the wall would take a load approximated as about 1,100-1,300 pounds. Even with this load, however, the first floor would be less than 40psf dead and live load after taking into account the planned changes. It seems to me, however, that actual wall load will only result from marginal deflection in the second floor joists. I'm inclined not to worry about this since the first floor can handle the "worst case" load but I'm not sure I'm thinking about this the correct way.
