Patch Design
Yashu
I'm new to patch antenna design. I'm trying to find out the best software to design 900 MHz F antenna's as well as some rectangular patches in 900 & 2.4G ISM bands.
I downloaded (free) Sonnet and tried a 2.4 GHz patch design with it. It's 37.1x28.9mm with coax feed at 18.5 and 7.1mm. It's on FR4 with er=4.48 and 1.6mm thick. Gnd plane is 100mm square.
After simulation, I see that the return loss peaks at a lower freq (2.38G) than expected (2.44G). So, I start to shave off the "L" length 0.1mm at a time and see the peak moving up. However, magically, at a certain point, this peak jumps about 50MHz even though I'm still shaving in 0.1mm decrements.
Is this a problem with the (free) Sonnet simulator?
How accurate are these simulators? Must I know the intricate details of RF antenna design in order to config the simulation parametrics?
What's the best software to purchase? Right now I'd like to pay minimal ($1K range) because I'm doing just rect patches... but, eventually will start doing smaller form factors and hopefully will have more cash to invest.
Thanks for any help.
Try changing the feed point as well... Most of the time they do have a significant influence on your operating frequency...
