AbdoulKarim
New member
i am currently working on a wing design and i need to define the maximum wing deflexion.
I have already performed the CFD analysis on a 3D wing and obtain all needed data.
I used the FSI mapping on fluent to import the pressure forces in Patran then perform a linear static analysis. however the results don't even appear as something must have gone wrong. maybe i's the method i used. as I am trying to apply the pressure forces on the top and bottom skin (surfaces) of the wing.
my full FEM contain
-a top surface
-a bottom surface
-ribs design as 2D surfaces
-and 2 spars (1D beam)
my questions are :
-Am I right to used the pressure distributions from Fluent to calculate the maximum deflection? in that case, what am I doing wrong, displacement constraint maybe?
-Should I import the forces instead of the pressure, or both? what is really need?
thinks in advance!!
my full FEM contain
-a top surface
-a bottom surface
my questions are :
thinks in advance!!
