Pattern Assembly Components - NX11
BrittToolEngineer
Aerospace
Aug 4, 2016
239
Greetings:
I patterned assembly components and off to the left out in space are dots associated with this pattern. Can these be hidden?
Brent
Perhaps the "dot" is a point object owned by the component that you didn't notice before and when you patterned the component, now you have a series of dots? If so, you can change the used reference set or edit the used one to remove the points and clean up the display.
www.nxjournaling.com
I believe at the top of the assembly navigator, there is a pattern indicator with a plus next to it. Expand the plus field. Then right click in the white area at the top of the field, and select the "do not display pattern in graphic window" or some other wording similar.
This is all from memory. I know these directions are not exact, but I believe they will get you close.
