I am simply trying to save a Solidworks drawing as a PDF and I get this error just after I hit save:
"Sheet Dimensions for "Sheet1" exceed PDF limits(200in x 200in)".
I measured the sheet simply by drawing and dimensioning a line the same length as the sides of the sheet and I get:
(34in x 21in) which is larger than normal but its not 200in. The principle dimensions are in mm and those values are greater than 200. Could that be a problem? The sheets print out just fine on a piece of 17 x 11 paper. Any suggestions?
