XR250
- Jan 30, 2013
- 5,755
I am helping an Arch. spec a PEMB. It is going to be one story and about 28 ft. tall with brick veneer.
I realize unless told otherwise, it will be designed to bare minimum code. I figure at a minimum I would specify L/360 for girt deflection. What about drift?
What other areas does it make sense to go above minimum without losing the economy of the building?
