Santiago Vacca
Materials
thread292-509093 closed, so I continue in this one.
When the MDMT is below -29°C lets say -40°C, and the welding consumable is classified by the applicable SFA below -29°C lets say E7018-1 -45°C.
for the base metal lets assume a stress ratio of 0.5 allows to reduce the MDMT of a curve B to -40°C.
[ul]
[li]wps is requiered to be impact tested because of Para. 323.2.2(h) allows welds stress ratio reduction to -29°C or,[/li]
[li]wps is not requiered to be impact tested because of Table 323.2.2 A-3 (b) allows welds to have its MDMT reduced to the SFA certified minimum lets say -45°C.[/li]
[/ul]
the following paragraphs of the B31.3 ed 2022 are:
Para. 323.2.2(h)
(h) For carbon, low alloy, and intermediate alloy steel
materials (including welds) that have not been qualified
by impact testing, the minimum temperature from
Table A-1, Table A-lM, or Figure 323.2.2A may be
reduced to a temperature no c o l d e r than -48 ° C
(-55 ° F) by the temperature reduction provided in
Figure 323.2.28 when (c) applies. For carbon, low
alloy, and intermediate alloy steel [highlight #FCE94F]welds[/highlight] that require
impact testing in accordance with Table 323.2.2, Box
A - 3 ( b ) , the temperature reduction from Figure
323.2.28 shall be applied to [highlight #FCE94F]-29° C[/highlight] (-20° F).
Table 323.2.2
A-3 (b) The weld metal of the
welding procedure qualification
test coupon shall be impact
tested at or below the design
minimum temperature when
that temperature is less than
-18° C (0° F), except when
Note (3) or Note (4) is satisfied;
testing of the weld metal
is not required when the clas-
sification of the welding
consumables according to the
filler metal specification
requires impact testing
below the design minimum
temperature.
[ul]
[/ul]
Para. 323.2.2(h)
Table 323.2.2
temperature.
