simaonobrega
Hello everyone,
Framework
I am currently working, for the first time, with perforated metal sheets. I am using them to create tubes and also curved panels.
To analyse my structure, I tried using FEM but I didn't succeed since my NX wasn't able to support the huge amount of holes (I have panels with approximately 3m x 1.5m). After searching for alternative ways to evaluate this case, I came across the possibility of replacing the perforated metal sheet by an equivalent solid panel with corrected values for the Modulus of Elasticity, E, and Poisson’s ratio, v (approach detailed at
My questions are then:
[ol 1]
[li]Assuming a solid body means that I am neglecting the stress concentration around the perforated holes. How do you normally account for this effect?[/li]
[li]I have seen corrections for the Young's modulus, yield strength and Poisson's ratio. Nevertheless, I have never seen corrections for bulk and shear modulus. Do you normally assume the same values for the latter two?[/li]
[li]Is there any reliable bibliography for the material properties detailed in point 2, as a function of material and hole pattern?[/li]
[/ol]
Thank you in advance!
Framework
[ol 1]
[/ol]
