Heldbaum
- Jan 27, 2017
- 128
Hello folks, please see attached sketch of proposed bracing. In a nutshell, my company is taking over the project that was done by other engineer. I already checked the structure of a new building but there is still bracing to be prepared by us. The attached sketch is what previous engineer proposed. Those 3 walls stayed in place and they need to be braced permanently. They can't remove those walls. The height is roughly 33' and the building width is 48 feet, from C1 to C2 is around 18'. The client doesn't want to do RC frame but he wants us to use steel instead. Any thoughts ? How would you brace those walls? Steel moment frame anchored to the masonry with hilti anchors ? And full lateral load on this frame? The wall thickness is 12"-16"..Thank you for any thoughts.
