crankPT
- Jul 12, 2017
- 10
Hello guys,
I hope to clearly explain myself on how i want to do this project, and i expect your comments because i want to learn and maybe something is missing me. I'm thinking about open a old gas bottle, properly clean it and connect the following: i had an old refrigerator, so i want to use the pumps to do like an hydrophore put maybe 15 bar pressure in the bottle, put two one way valve in each connection from the pumps to the bottle, put a safety valve, 2 limit switches, and i am still thinking in the fluid, water maybe? then the discharge from the bottle is connected to a pelton turbine, and here i am thinking in to connect a shaft in the pelton for two small wheels (out diameter =350 mm).
I am worried about the pumps can't keep up with the flow, the force exerted on the pelton i don't know if its too low (i've to do the calculations), and add the inertia of the shaft and wheels, to do like a small kart or instead of wheels put a propeller and do a river boat (i live near a river).
So what you think, seems executable? can i improve somehow?
Thank you very much
Thank you very much
