edison123
- Oct 23, 2002
- 4,460
If a VFD has a sinusoidal output filter and if the V/Hz ratio is maintained, can we connect a PF correction capacitor across the motor terminal fed by this VFD? Will this reduce the VFD output current (since motor no load current is compensated by the capacitor current)?
Muthu
Muthu
